I found this, I hope it helps.
Good luck with the move.
2007 NISSAN VERSA
Engine: 16-valve, 1.8-litre 4-cylinder
Horsepower: 122 hp at 5,200 rpm;
Torque: 127 lb-ft at 4,800 rpm;
Transmission: 6-speed manual; 4-speed automatic; Xtronic CVT
Suspension: independent/semi-independent
Brakes: disc/drum
Wheelbase: 260 cm
Length: 429.5 cm
Width: 169.5 cm
Height: 153.5 cm
Weight: 1,235 to 1,261 kg
Tires: P185/65R15
Maximum towing capacity: forbidden
Airbags: dual front, plus two side and two curtain airbags
