towing question
bg113
Car: 1993 nissan hardbody
I've got a 93 hardbody 2wd, 2.4cyl automatic with overdrive, and I'm trying to figure out what the towing capacity for this truck is as I plan on building a camp trailer to pull it with. Any information would and will be greatly appreciated. Thank you for your time.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I don't think you will want to tow too much before installing a transmission cooler. How heavy would you say the camper trailer is?
smurfmobile
Car: Nissan D21 King Cab 4x4 V6 lifted 36" 1991
Nissan D21 King Cab 4x4 V6 original 1991
I wouldn't do much of towing unless you install a transmission cooler as Rev said.
bg113
I'd say between 2000 and 2500lbs
Rev_D21
According to my Nissan Towing Guide manual the 2wd 2.4l Auto is rated at 2000lb max trailer weight, 200lb max tongue weight and 5500lb gross combined weight.
turner
Car: nissan pickup 1993 v6 4x4 VG30E
i decided to use this old thread:
i have a 1993 v-6 4x4 manual hardbody, wondering what the safe tow weight is.
i want to tow a 5x8 enclosed trailer, which tends to rate at 3000 gross, 900 trailer and 2100 contents.
i have had a difficult time finding this info on the web or finding a nissan towing guide manual applicable to my truck. thanks.
Edit/Delete Message
