Did you get the Curt hitch? Did you use the straps when you had the bike rack on it?meanie wrote:I've been using a hitch for years on my AWD E35. Besides a bicycle rack I also tow a converted single place snowmobile trailer with two kayaks on it in the summer. In the winter I tow a two place snowmobile trailer with two 600 lb sleds. So I am pushing the weight limit. I usually tow it over a hundred miles north and leave for the winter with occasional shorter forays to local trailheads, and then bring it back home in the spring. No problems except it might cause some premature brake wear.
Do you use a bike rack or non-trailer load? If so, have you used stabilizing straps? Are they necessary?mrzuzzo wrote:My Curt hitch definitely doesn't vibrate or impact the exhaust in any way.
I didn't install it myself but the technician who installed it also used a Curt harness, I believe.
Sorry for the late response. Haven't been on the site in a while. Yes it is the Curt hitch, but I had it installed at a shop. There initially was a problem with the exhaust hitting on bumps when the tongue had a load on it. Bending the "ears" on the hitch took care of that. Otherwise, no problem. Not sure what you mean about straps unless you are talking about the kind that mount on the hatch. My Thule rack slides right into the hitch opening.jsheahawk wrote: ↑Wed Mar 15, 2017 8:37 pmDid you get the Curt hitch? Did you use the straps when you had the bike rack on it?meanie wrote:I've been using a hitch for years on my AWD E35. Besides a bicycle rack I also tow a converted single place snowmobile trailer with two kayaks on it in the summer. In the winter I tow a two place snowmobile trailer with two 600 lb sleds. So I am pushing the weight limit. I usually tow it over a hundred miles north and leave for the winter with occasional shorter forays to local trailheads, and then bring it back home in the spring. No problems except it might cause some premature brake wear.
Really? I had a hitch installed on my EX35 with the intention of using it for a bike rack, and the place that did the install didn't say anything about straps.
Mine was professionally installed and nothing was said about straps, but I didn't see the box it came in. My first hitch was damaged when I was rear-ended so the body shop ordered and installed another. They also did not mention straps.
I just found this page that states the QX50 does indeed have a trasmission oil cooler.
