Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Oct 31, 2007 7:41 am
You should be fine putting the Tcase in neutral and towing that way. The front hubs are free running, so nothing in the front drivetrain turns anyways when in 2wd.
If you really want the added insurance, drop the driveshafts (8 bolts on the front one and 4 on the rear pinion yoke). You will want to plug the tcase output when you do this, though, as it will leak gear oil with the DS removed. As for the output bearing, I'm not dead sure on what you're referring to, but if you're talking about the Tcase, it's got oil in it and will self lube if it's spinning.
An alternative would be to just unbolt it in back and wire it up to the frame, leaving the slip yoke in the Tcase. Just make sure that it doesn't get in the way of wheels and suspension movement.
