alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.html
Fri Mar 26, 2010 11:17 am
is the car on a hauler or on a dolly? an aluminum tandem axle Uhaul hauler is a lightweight comparatively, and they weigh 1100lbs. if you're using a steel tandem axle hauler, it's going to be closer to 2000lbs for just the trailer.
and your 240SX probably weighs close to 3000lbs.
without trailer brakes, i wouldn't even pull that kind of weight around town, and especially not on the mountainous highways of California.
will it do it? yes. will you enjoy it? no. will your pathfinder enjoy it? certainly not.
you risk overheating the transmission, and you will certainly cook your brakes. your brakes may not fade too bad, but they certainly won't be up to the task of an emergency stop.
so, i guess it all depends on if your pathfinder has a trailer brake hookup, and the trailer has brakes on at least 1 axle. even still, i hope you're ok with doing 5500rpm full-throttle in 2nd gear, just to maintain 55mph on an uphill grade.
