I wonder how they get back DOWN. Brakes. BRAKES! Only designed for a 35 lb car!Jesda wrote:Going back and forth across this country, I've seen Metros and Cavaliers pulling huge trailers full of stuff. Scary. I wonder how they go over a 2% grade?
Why it is best to keep it in 3 until at least 60 mph, unless it is perfectly flat (or downhill), ambient less than 100° F and speed is constant.Q45tech wrote:TRANSMISSION and its 4th gear TC lock up clutch cycling its life away with the extra load............ever notice how much even the unloaded Q cycles at 50-55 mph on slight inclines mild accelerations with AC on.............not enough torque at low rpms........a fact of life with 4 valve per cylinder engines.
