jspec603 »
https://forums.nicoclub.com/jspec603-u49563.html
Tue May 27, 2008 10:56 am
I actually used to manage one of the local U-haul's in southern NH. The low ground clearance they are talking about is due to the area where the nose of the car come in contact with car before the tires start up the ramp. They also are cautious of the center point of the car when the front tires are on the top of the trailer and the rears are on the ramp. MOST of the time these are only precautions due to liability. I have personally used those types of trailers to tow a variety of different cars, one being my lowered and kitted 240sx. I basically found a low point in the driveway where the tires of the trailer would sit lower and the ramps would come out straighter on the slight up hill slope. The other option is to use some 2x6's and place them under the ramps to create a longer and less steep angle of approach. What ever you do, don't have the towing vehicle pointing on a down hill slope. You will do nothing but increase the angle of the ramps and make it more likely to damage the under side of the car.
With that said, GOOD LUCK!
PS, make sure you have them inspect the tires for uneven wear, tire pressure and wheel bearings on the trailer. Have them do this with you standing there. Shhhh, don't tell anyone, but the trailers are the most over looked equipment in the company.
