BlackMetal »
https://forums.nicoclub.com/blackmetal-u136107.html
Mon Aug 31, 2009 12:47 pm
ah, it was cake!
the harness runs along the driver side, over the rear wheel well down below the stryofoam jack support/storage and up to the LH light first, then splits there and continues to the RH lamp assy. via under the trunk sill plate.
the wire harness is very tight, no real room to cut, solder, heat shrink, etc... so the best option was to strip about 1/2" off the wire (not cutting it) and twisting the conversion module wire to it and soldering, then cover with tape. when all done with all the wires, just make it neat and tape things up...
converter is hidden on rear body panel under the LH lamp assy, and grounded to the metal extension just below the filler door...
we`ll see how she does towing maybe this coming weekend, it`s just a short distance...
