towing a trailer with versa
wil333
does anyone know if you can tow a small boat with the versa
any info would help
thank you william
matt_a
wil333 wrote:does anyone know if you can tow a small boat with the versa
any info would help
thank you william
Hi William. The Versa probably can tow a small boat, but you would be doing so at your own risk. The owner's manual specifically says not to tow with the Versa, so if you do and you have any problems with your drive train or breaks, you will have voided your warranty. I'm sure the car is capable, but you have to decide if it's worth the risk.
lain
Car: 2007 Nissan Versa S
make sure the whole trip is at level ground
Vahagn23
Car: Nissan Versa S
it probably will tow, but I dont think its engine was made for towing, the manual said not to carry more than 1400 pounds inside of the car, but then again with 126hp isnt much towing power
ThirstyRoss
The Tiida manual says you can tow up to 600kg, so I think the Versa can tow to the same limit.
As someone previously stated though, if you damage your Versa from towing, it will not likely be covered under a North American warranty.
PS: Vahagn23, the Versa has 122hp, not 126hp. Just a minor detail, of course
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
I've towed quite a bit with my Versa. It does an excellent job. .. for a compact car. It tows as well or better than my '03 Corolla which was rated at 1500lbs. On steeper hills you do need to downshift to 5th at freeway speeds. Otherwise I towed a 900lb trailer (600lb motorcycle+300lb trailer) and the car was loaded down with 2 adults and luggage for a week plus riding gear. The rear end bottomed out occasionally, but the car was MORE stable
I towed my motorcycle from Iowa to Central Colorado (Colorado Springs, Aspen and Estes Park) including going over Independence Pass, Loveland Pass, Vail Pass along with Tennessee and Hoosier Passes. On Loveland Pass I maintained 45mph in 3rd gear and was still passing semi's so I figured that was good enough.
Since then I've towed my new, larger touring motorcycle which is almost 650lbs. No problems.
Get the Curt hitch. It's a better design than the Hidden Hitch, Drawtite and Reese. I'd also consider getting a air ride hitch. Check out "Air Safe Hitches" on the internet. I have one and it isolates 70-80% of the vibration and motion of the trailer.
I'd be comfortable towing a boat/trailer up to about 1500lbs if it had trailer brakes. I wouldn't tow more than 1000lbs without trailer brakes.
I wouldn't tow more than 1000lbs with the CVT.
