Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Wed Feb 24, 2021 1:03 am
Manual hubs on the vehicle is fine. No concerns there, towing wise. It's the rear axle spinning up the transmission that's the problem.
Converting the rear axle to full float plus manual hubs is extreme. I'd expect the cost of any such work would exceed the value of the vehicle, whether it'd be customizing the H233B axle, or outright replacing it with a Toyota rear axle where full-floater kits exist for it. The latter is the approach I'd go, money being no object, but that's one helluva downward spiral on the wallet. It'd be cheaper to just buy a car hauler, despite having to tow more weight.
The driveshaft disconnect is interesting...I just learned that existed the other week. I don't care for the engagement assembly hanging off the pinion snout the way I've seen it installed. I'm sure it all works fine, but it just looks janky to me. For what seems to be about a $1K job between driveshaft modification and installation, it doesn't seem all that terrible of an option, all things considered.
If you're really keen on towing a 4wd Nissan SUV that's similar to the QX4, I think you have your 1st answer: buy a manual transmission Pathfinder or Xterra. There weren't MT QX4s...all are AT+All-Mode, and particularly for the All-Mode, Nissan expressly says to not tow it with any wheels on the ground (Nissan didn't account for manual hubs of course because they weren't factory items). Availability (or practical odds of finding) those vehicles with MTs varies by years and generations. And if none of those will do, I think you have your 2nd answer: Jeep.
