C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Apr 08, 2007 10:40 pm
pac-audio has an interface that will work with the steering controls and basically turns it into a universal remote. However, it requires the headunit to have a compatible IR receiver and it's not without it's quirks. It tends to provide a delayed signal (about 1/2 second) and can only handle a limited number of functions. Though, I'd imagine if you are just using the steering wheel controls only, then you should stay within the maximum number of functions. I had mine hooked up to a SAT channel adaprter on a G35 which also allowed me to program many of the buttons on the factory stereo itself to IR commands.
As far as bluetooth, I'm not sure. If it's integrated t the OE stereo, then you'll probably lose it. However, if you're going aftermarket,there are many headunits that have Bluetooth modules you can attach.
