Touched MAF now revs reading is nuts
Lopin18
Car: '89 Nissan 240SX Hatch KA24E
Hi, KA24E 89
I dismounted the maf with its plastic tuve all the way to the entrance to the Throttle, checked the Radiator some hoses had to be disconnected, then assembles everything just fine
car is idling ok, neat, weird vibrating sound below the car, like something touching, scrapping with another metal, someone said might be the transmission and the pressure plate or something
now the problem is the REVS reading is jumping, idle keeps normal but the reading is wrong on the gauge, it was fine before i touched everything, im idling like 800 rpms, and the gauge is 0 500 200 700 like that jumping,
when cruising it tried to keep up, but still jumping around, the car ran great and i stopped the gauge now doesnt even moves, stays in 0 and SOMETIMES every 5 secs he kindda jumps to 200 and puff down again
MAF right??? what can i check?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
MAF doesn't have anything to do with the tach... The fact that you messed with the maf at the same time is coincidence.
Lopin18
Thx just needed to confirm the maf not involved,
well the engine is working great, but the tach jumping around is really getting on my nerves... im gonna check all plugs and stuff for damage or burnt, any tips where i might start checking? ill just check around everything i touched
