Thanks for the input. I'll try the pen and I also like the fact you can clear coat it afterwards to seal it in.BBISHOPPCM wrote:I have used both the pen, and the brush/bottle. The pen is far superior, as it allows a nice, smooth stroke. The pen can be used on either the body, or the plastic bumpers.
The Edge wrote:There are 2 versions available thru Nissan
1- Brush type
2- Pen type that also has a clear coat on the other end.
Which would be best to apply. It's for the rear bumper.
OUCHHHHHHHH man that sucks, dude you might need a body shop for that, i dont know much about the paint but that looks bad.nimasa wrote:would the pen fix this:
No, pen would not fix this, this repair requires sanding of the bumper, and re-applying primer, paint, and clear coat to build back up, and re-finish it. A good body shop will be able to fix that for around $600, if you are able to take off the bumper yourself, and take it to the shop, it might be half that price, which I would recommend, because it is soooo damn easy to take off.nimasa wrote:would the pen fix this:
