You posted a link of someone that has the same issue... lol. How in the world is tellin him that other people have had the same issue gonna fix his???
Anyways, this happened to me with my swap. First things first, have you played with the clutch adjustment at all? If you look you'll find the push rod that compresses the piston assembly connect to the pedal. Is that adjusted properly to place the pedal farther away from the firewall?
If you've tried that, have someone bleed from the slave once more, then also at the clutch master cylinder itself. Sometimes a small pocket of air gets stuck close to the top. That should fix it.
