R240NA »
https://forums.nicoclub.com/r240na-u1367.html
Sat Dec 07, 2002 4:53 pm
Same motor, of course it will swap. 89-90 SOHCs will need to be rewired and set up for a DOHC, but 91-94 drop right in. Use the S13 intake and exhaust manifolds for asthetics, and use the S13 wiring, ECU, and distributor. Basically, you'll be swapping the longblock and accessories. You can use the S14 manifolds, but you won't need 90% of the emissions equipment. The head and upper front cover are slightly different between S13 and 14, so keep it all off the 14 motor.
