Phram1 »
https://forums.nicoclub.com/phram1-u217282.html
Thu Apr 03, 2014 5:27 pm
You are correct, SDS EM4 6F.
MAP timing - Yes. I have established an RPM timing and map timing values can be adjusted up or down. For example, at 3000rpm the RPM timing is 32, then at 10lbs boost it pulls 15 degrees out leaving a total timing value of 17. In turn, if I am traveling down the free way at 13 in vacuum then I have set it to add 13 to the mix so I am running 45 degree total timing.
Why SDS, because in 2001, this set up was recommended by a local tuner and I knew very little about the world of EMS. Now 13 years later, I am far more educated it is time to make a move. First step, change out my T3/T4 journal bearing turbo to a GTX3067R dual ceramic ball bearing turbo, this was a great move. Now the next step new EMS. But till this comes about, I am looking to further refine the existing system. Hence the reason for this thread.
Thank you for the Nistune recommendation. And now you know more.
