SR20Essex »
https://forums.nicoclub.com/sr20essex-u41694.html
Fri Dec 01, 2006 12:34 pm
I like my setup which is more for performance (3+2+4+8=17):
1989 240sx (260whp 13psi boost, 0.97G's on the turns, breaks like a champ, reliable as a daily driver)
Motor & Drivetrain: 1996 SR20det with VVT ( 5qt of Mobil-1 advanced supersyn 10/30wt), S15 Turbo, Greddy divorced chamber dump pipe, 3in down, 3in to 5in Apexi N1 exhaust system, S14 Greddy FMIC (fits with a little mod to the front end), Transmission from a N/A SR20DE car (running Motul 75/90wt gear oil), VLSD from an S14 silvia (5bolt pattern, with Redline 90wt gear oil), huge Fluidyne radiator (dexcool), Exedy clutch, Oil Cooler (made some brackets so its secure), remote oil filter relocation kit (its a must, I use the same Mobil-1 filter as a 1999 volkswagon cabrio because they are huge, extra 1/2 qt), Greddy oil pan, Lightweight pullies, UR underdrive pulley, gatorback belts (nice and quiet), NISMO thermostat, NISMO water pump, Smaller battery (a bit of fabrication work for it to look nice and be safe to get by the FMIC pipe), also a must is gauges for making sure everything remains in spec (oil pressure, oil temp, water temp, boost pressure)
Suspension: sway bars & upgraded links, polyurithane bushings, ball joints, tension rods, tie rods, upper and lower adjustable camber arms, front and rear strut tower bars, KYB shocks, eibach lower springs.
Wheels Tires Breaks: Sportmax 962's 18x9.5 rear, 18x8.5 front with Toyo T1-R tires (very sticky, only good for 15k miles tho), 5lug hub conversion, Polychromalloy front 5 lug, standard 5lug conversion in the rear, front premium vented 300zx rotors, rear S14 5lug slotted rotors in the rear, 30mm Aluminum 300zx calipers, 300zx Master Cylinder, Steel braded break lines, Motul DOT-4 break fluid, high performance cerametallic pads, Motul Dot 4 break fluid.
This in my opinion is the ultimate setup; handles like a Porsche, accelerates like a Corvette, looks like a stock 240 with nice wheels and an exhaust. I did nothing to the exterior but take off the stock rusted wing. The interior is stock, but the only think I plan to do with that is a racing style seat (Recaro).
Feel free to ask me questions; this is the best bang for the buck in terms of performance for the car you have.
