Total Bushing Replacment
bwirth1999
I need to replace the bushings in my 96 240, and was wondering if it is something easy enough for me to do myself, or if i should have it done by a shop? Also Are energy suspension bushings the best out there for the money?? It seems thats all anyone carries.
gumby74
If you don't mind getting dirty, and you have access to a vise and maybe a torch (small propane ones will work) you can remove most of the bushings yourself. At some point you will need a press.Someone local was parting out a car so I picked up the front and rear control arms and hubs, removed several bushings myself, installed a couple and had the rest pressed in/out. Ended up costing me about $150 after everything.I need to install the rear control arms, probably this weekend. Keep in mind my car is my daily and I could not risk getting hung up without a car for too long.As for the quality of ES bushings, you would be hard pressed to fing a better produst for the price. I have some ES suspension bushings on my 4x4 going on 10 years, no worries. And I take her out at least a couple times a month aside from some daily driving.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Huge pita if you know what you are doing and have the right tools. A vice, giant c-clamp, and torch will help. As well as a sawzall to cut the inner rings. Plan on being down at least a weekend maybe more because you will always run into a problem.
gumby74
This man speaks truth.If you have patience, tools and are not easily frazzled, you should be fine....eventually.Thats why I got me spare arms to work on off the car. hint hint
98s14inaz
In hind sight I wish I did that. Not that it is done I love it, the bushings are definitely worth the effort.
runnerb240
All you guys that did this I have a questions. I am in the middle of replacing all mine, and I was going to do the front sway bar bushings, but I got confused. In my kit I got 2 square pieces of metal with a hole in it and I can't figure out where this would go? Anybody know?
Thanks!
Ohh and it definitely takes at least a weekend. I been doing mine all weekend and still have the fronts to go. I also did some brake work too though.
98s14inaz
Under the new brackets and bushings for the sway bar. Start bolting up the sway bar and you will see where it goes.
