Torsion Bars
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
85NAPSZ
Car: '85 Nissan 720
'90 Toyota Corolla
Does anyone know how many clicks or turns of the torsion bars it takes to lower the front end around two inches?
PEZi
it's kinda just play around and see.... try about 8-10 full bolt rotations
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
You may want longer blots than stock or drop spindles for 2". But, IDK what Stock can handle.
PEZi
breadbox wrote:You may want longer blots than stock or drop spindles for 2". But, IDK what Stock can handle.
the bolts on mine were enough to take it to the ground if i wanted....
MetalFab
Car: 1985 720 4x4 reg cab flatbed.
Had 3.5 inches of bolt sticking out above the nut, and the nuts are fairly long themselves. Although I'm thinking whoever had my truck before me cranked them way too high. What I've done to lower the front end is first to see if your frame sits level on it's tires, measure from tire to fender on both sides, you'll want to do this often through the process. Back down each bolt evenly, counting 1/4 or 1/2 turns and do the same to the other side until you reach your desired height. Hop up and down on the hood a few times after each adjustment, some even say go for a short test drive, this will settle out your suspension and show you where things will really sit.
breadbox
89 Koop
84 720 4x4KC
I never plan on dropping it so I might never touch mine.
Charlie69
Car: 1966 Datsun 520
It is better in my opinion to measure from the ground up to the botom of the frame on each side beneath the radiator. This takes out the possibility of a crushed/worn out or unevenly tightened body support. On the last 521 1 click = about 1" drop.
MetalFab
Better to measure from the frame for sure. Also measure the back on level ground, from each frame rail to the ground. Spring sag, uneven tire wear, tire pressure, etc could change everything. Guess it just depends on how much detail you want to get into. Like lifting, lowering also effects overall alignment. I'm not sure about the corrections available to lowering, as the upper a-arm is mounted differently in 2wd than 4wd. I plan to find out soon when I start my 620 project, but I'm sure someone here might have some answers on the subject. Good luck =)
slvrwrx
Car: Datsun 720 Pickup
2.4l, 2wd, 5 speed
short bed, short cab
can someone post a picture of where the bolts are that adjust the torsion bar allowing you to lower the front end?
PEZi
Return to “Datsun 720”
