dudes hessianben uses the sway away torsion bars on his frontier. by the pics of his auto x ing he still has body roll even with a rear sway bar and other goods, but im sure its better than stock
i got my belltech rear springs and "nitro drop" shocks from summit then autocrossed my 97, still waiting for the rear sway bar. still the belltech spring in back really stiffened things up, but the front is still uber cushy and rolling. nevertheless i found the front roll helped the rear rotate thereby lessening all the understeer these trucks have...anywy these are the two options i have considered
sway a way bars and pinto/camaro koni adjustable shocks in front, calmini idler brace, addco sway bar rear, panhard bar
same as above but mustang ii (street rod) coilovers (7.6 inches compressed! really short) 500lb/in with qa1 12 way adjustable shocks, and lennening weight by throwing out the torsion bars and other stuff
same as intial setup but larger front coilover and a custom mount if the street rod coilovers cant fit... but i think they will if i cut the bumpstop mount out of the way. both setups though radically different cost about the same cause the bars are 220 and the shocks are 100 each, while the whole mustang ii kit is 380-450
btw pezi check out these sway bars!
http://www.summitracing.com/se...dds=1
