DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Sep 25, 2003 12:06 pm
10mm bolts? I don't have a 240 FSM handy, but don't confuse the diameter of the wrench you use on the heads with the size of the bolt. The shank doesn't care how big the head is, but if you apply the "standard torque" for a 10mm bolt on a fastener with a 6mm shank, it will shear off (at the shank, not the head). Look in the FSM under the General Info section for standard torque values. The sizes referenced are not for the heads. 10mm bolts take around 30 ft-lbs standard for a grade 7 bolt.
120 in-lbs (10 ft-lbs) will generate roughly 60ksi of stress on a 6mm bolt (for example), which isn't too high for good steel, though there's always some bending involved when you use wrenches, and this ups the stress a little. But it's probably good, as you found. I just think it's good to be sure about things beforehand, that they'll work right and that they won't break.
