Torque Wrench Question..
steelcity
Car: 2007 Infiniti M35x
This is regarding the installation of the Plenum Spacer that I'm working on.
I found an inch-pound torque wrench that goes from 20lbs and up.
When installing the TB back on, it says to do 10 lbs- 30lbs- 50lbs.
What happens if there is no 10lbs on the torque wrench? Can you just do 20 lbs and then go to 30 lbs and then 50 lbs?
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
If it were me, for the first. I'd just go with hand tighten. 10lbs is about the same.
EniGmA1987
Car: '06 Infiniti M35 Sport
Hand tighten with your fingers, not a wrench or anything. 10 in-lb is an incredibly small amount. I can do between 50-60 in-lb with just a screwdriver type socket wrench, well over that with an actual socket wrench.
steelcity
thanks guys
