Torque Values
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
deerio
Car: '63 L320
Hey all, just wondering if there is a list/document anywhere that shows what the torque specs are for all the different nuts and bolts on the 320? I managed to find something that lists some 620 values but nothing for the 320 or 520/521. I was interested mainly in the engine, transmission, suspension, and brakes. Thanks!
Conner
Car: SRL31101633
1964 L320
There is/was a CD with a ton of great 320 reference material available from Alan Bent in Australia. His website says he is sold out but may be able to track one down. If I were you I would shoot him an email. I have his CD and it is really useful.
http://www.earlydatsun.com/shop.html
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
deerio,
See the Datsun 320 Manual v2 for torque specs. Page 24 list the head specs with a schematic. However, you will have to read through manual for other torque specs as there is no schematic or torque sequence.
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '60 PLG-222
Here are the torque specs from a MGA / 3 bearing early MGB -
Flywheel to crankshaft bolts @ 35-40 lb-ft.
Cylinder Head @ 50 lb-ft
Rocker Pedestal bolts 5/16" @ 25 lb-ft
Connecting rods @ 25 lb-ft
Gudgeon Pin clamp bolt @ 25 lb-ft
Flywheel to Crankshaft @ 35-40 lb-ft
Clutch Cover to Flywheel @ 25 lb-ft
Water Pump bolts @ 25 lb-ft
Manifold nuts @ 25 lb-ft
Camshaft nut @ 100 lb-ft
Crankshaft nut @ 100 lb-ft
Valve Cover @ 5-10 lb-ft for the 6 screws. If only the two grommets these will need to be a little more, especially if you have new grommets.
If in doubt of torque specs you can use these -
3/8" @ 35-45 lb-ft
5/16" @ 20-25 lb-ft
1/4" @ 10-12 lb-ft
Again verify torque spec from one of the Datsun Manuals first. If not listed or cannot find these numbers should be good as the E1/J13 is an undersized copy of the 1500cc found in the early MGs. I'm still looking for sequence order as I need these on my '64s E1 and will post once I find them.
Return to “Datsun 320”
