p00t »
https://forums.nicoclub.com/p00t-u5026.html
Fri Feb 13, 2004 4:59 am
I have a 93 240sx FSM so i can only give you the values for the DOHC engine.
Tightening procedure:a. tighten all bolts to 22 ft/lbsb. tighten all bolts to 59 ft/lbsc. losen all bolts completelyd. tighten all bolts to 18-25 ft/lbse. tighten bolts to 55-62 ft/lbs
I dont know how the head bolts go on the SOHC but heres the tightening order for the DOHC (10 bolts in all)
9 - 3 - 1 - 6 - 8|7 - 5 - 2 - 4 - 10
basically you do the two middle ones, then you move over and do the next one and cross to its opposite
