Torque Steer? 2011 Quest SL
A forum for the Nissan Quest... minivan lovers unite!
smacd70
Car: 2011 Nissan Quest SL
110K
Under hard acceleration, my 2011 Quest SL with 110K miles pulls significantly to the left. More disturbing is when I let up on the throttle, the car swerves hard to the right for a half a second.
I believe this is all being caused by worn suspension and/or steering parts that are allowing significant torque steering issues. Does anyone know which parts might need to be replaced?
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
It can be literally anything under there. Often control arm bushings or balljoints.
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
1) tie rod ends
smacd70
110K
It was BOTH the lower right control arm bushings AND the right tie rod end.
$600 later, it drove great.... Until the AC quit after just 500 miles more. Right CV joint died 100 miles later, and 150 later the alternator and voltage regulator went out! 200 miles more and I ran over nails which puncture 3 tires...in the sidewall! Almost $5000 repairs later and my van can finally be driven!
The mechanic said motor and Transmission mounts need to be replaced and the front struts are bad! All this on a van with just under 112000 miles!
amc49
'17 Nissan Altima
The new Nissan circa 2000+...................they are NOT your father's car any longer.
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
.....at least your CVT didn’t crappy out yet....
This is the first Nissan product that disappointed me
Return to “Quest Forum”
