corn322 »
https://forums.nicoclub.com/corn322-u6695.html
Sat Jul 19, 2003 11:43 am
other than,"FRONT DISC BRAKE CALIPERRemovalRaise and support front of vehicle. Remove wheel assembly.Disconnect and plug brake line from caliper. Remove caliper mountbolts. Remove caliper assembly.InstallationTo install, reverse removal procedure. Tighten caliper mountbolts, and bleed hydraulic system."(same for rear), this is all it's got:
application................................ft. lbs. (N.m.)240SXBrake Line Bolt .......................... 12-14 (17-20)Brake Line Flare Nut ..................... 11-13 (15-18)Brake Pedal Fulcrum Shaft Nut ............ 12-16 (16-22)Caliper Pin Bolt ......................... 16-23 (22-31)Carrier-to-Mount Bolt .................... 53-72 (72-97)Wheel Bearing Lock NutFront ............................... 108-159 (146-215)Rear ................................ 174-231 (236-313)
