torque specs on connecting rods?
ScottieDoritfto
Car: 1990 s13
what are the torque specs on the CA's connecting rods turbocharged? i cant seem to find it anywhere
thanks
progman
Check the DSM. I think it's around 38ft/lbs
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
progman wrote:Check the DSM. I think it's around 38ft/lbs
FSM.
The link to DL it is sticked at the top under "Writeups/FAQs" or whatever it is.
boost_boy
ScottieDoritfto wrote:what are the torque specs on the CA's connecting rods turbocharged? i cant seem to find it anywhere
thanks
Don't exceed 35 lb/ft of torqu with your minimum at or around 32 lb/ft of torque.
Dee
meminto
Car: S13 Silvia CA18DECT
Hi mate,
There is a process to follow when torquing the rod bolts on the CA turbo:
1. Tighten 10 ft/lb then 12 ft/lb2. Tighten 30 ft/lb then 33 ft/lb
If you have the workshop manual, check out page EM-42 for clearance tolerances
Hope this helps
