Torque specs for the SR20?
I'm reassembling the SR (manifolds, valve cover, brackets, transmission, etc) but don't have torque specs - can someone help (link or email)?
Thanks all!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Tsk Tsk... need to download FSM from phatg20.net
But I will help ya out:
Exhaust Manifold- 27-35 ft/lbIntake Manifold- 13-15 ft/lbValve Cover- 69-86 Inches/lbTranny bolts- small diameter( 22-30 ft/lb) large diameter(51-59 ft/lb)Oxygen sensor- 13-17 ft/lbPower steering bracket- 33-55 ft/lbspark plug- 14-22 ft/lbwater pump- 12-15 ft/lbWater pump pulley 57-59 Inches/lbmotor mounts 33-40 ft/lbaxle shaft nut 145-203 ft/lbLug nuts 72-87 ft/lb
If I forgot to tell you, CHANGE THE DAMN WATER PUMP if you don't, you will hate life later..... trust me.
As far as the valve cover nuts go.. start with the middle and keep going in a spiral circle outward. Keep doing this sequence until they are within specs.
Anything else?
Perfect.
I dl'ed the manual, for some reason it won't "read"....
Thanks man!
