mac,your talking "hot wiring" the solenoid, that is heavy(Red) cable from starter to pos. battery , a FUSED jumper from solenoid (ign. tab) run , just momentarily "touched to pos." battery term? BE CAREFUL - here's what happened in my 93 J - I needed to do this and being overly SAFETY conscious , I LOOSENED NEG. Battery clamp ready to "pull the plug" if needed!
I DID ,because the solenoid DID NOT DISENGAGE (test w/key OFF- I had also removed f/pump AND ECM fuses-glad I did). Treat everything like an EXPERIMENT. I had to install a heavy Shottkey "blocking" diode in wire going BACK INTO IGNITION Ckt.!
to prevent SOME SORT of BACKFEED, I believe was from the Theft Control System , NO OTHER CAR I've jumped solenoid EVER DID THIS.Do it w/loose conn. on neg. , AND pull fuses to prevent start ,OR YOU'LL CHEW YOUR FLEX-PLATE & GEAR on starter with engine running!!
When it works , AND DISENGAGES WHEN RELEASED ,then go ahead and put fuses back - but I would keep the neg. battery clamp loose , just in case starter didn't properly "cut-out"
on FIRST TRY - "ALL IN" .
