MinisterofDOOM wrote:The pan bolts should be tightened to 61-78 ft-lb.
That should be 61-78 inch-lbs. About 6 ft-lbs. Really just need to be gently snugged, if you don't have a 1/4-in drive torque wrench.
Overtightening these bolts tends to strip the threads. Also the FSM recommends replacing the bolts with new ones - about $1 each from a dealer. They have an orange anaerobic sealant on the threads.
Draining and dropping the pan will empty out about 6 quarts of ATF. Measure it after you drain it out.
