torque sequence for upper plenum
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
i must be tired. swear i saw this somewhere in fsm, but now can't find it. i know EM-6 has the actual tq values of 8-11 lb-ft, but can't find the sequence.
DAEDALUS
Car: 1990 Infiniti Q45
I don't recall seeing a numerical order for the plenum (maybe you're thinking of valve covers?), but there is a clear procedure for assuring good alignment when all is said and done. You need to snug the plenum down with the runners and then remove the plenum to install the fuel rail. It's toward the end of the section for timing chain installation.
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
I've never looked up the squence. I just start in the middle and work in circles/spirals towards the outer-most bolts. Have done it three times no problem.
I probably do more passes than typical too. I start out by using a stubby wrench and holding near the head so I don't apply much torque.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
aight. musta been hallucinating--there are clear torque sequences for most things.....my backup is to do it as suggested here.yes, i did follow the alignment procedure.
at least this intake is light compared to my old cast iron v8 intakes of the late 60's cars.
DAEDALUS
I'd guess the casting is too rigid to worry about warping, plus the gap is determined by the solid metal rings inside the gaskets. Still, never hurts to use the inside-out star pattern.
