Torque Plate for Datsun L28
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
raremotive
Car: 04 Infiniti G35
Anyone know where I can find a torque plate for a L28?
Thanks.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I know a guy that made his own out of an old cylinder head, you plannning a large overbore?
raremotive
from 86 mm to a new 86.5 mm... not much really..
Because I am not speaking for L-series.. but RB.. L28 have large enough bore and same cylinder pattern.
Modified by Rare_f8 at 10:40 PM 11/4/2008
evildky
06 Nissan 350Z GT
ah, yeha I know the head bolt pattern, cylinder spacing etc was the same but wht the trque plate for such a minor overbore? I thought the rb was a stout block?
and I am sure you can find a used L head for a heck of a lot cheaper than an rb head if you wanted to make your own
raremotive
interesting suggestion. Every little bit helps. Just a picky intuition I have.
evildky
06 Nissan 350Z GT
FWIW, I'm boring out my L28 .10 over and not torque plating it
raremotive
Yeah if, I had an L28 I would too. But for me the high hp, boost and rpms. I just rather have the knowledge of a proper toleranced block, not assumed. Every little bit helps.
evildky
06 Nissan 350Z GT
how high HP we talking? my "L30" should put north of 450 whp
nothing wrong with being over cautious, I know when dealing with the honda motors torque plating is a must as they flex too much, but the L and I assume the RB are stout enough to take it
raremotive
700 minimum, 10k rpm, boost.. unknown.. at this point.
Honda's has aluminum blocks which makes them so ductile.
However even "stout" cast iron flex a tiny bit.
Ideally would be to run heated oil to get the block expanded to operation temperatures and with a torque plate bore and hone.
But torque plate is enough for me.
Stealth-Z
Car: 1991 300ZX
The torque plate idea floated around my mind for a long time. Finally I wanted to see for myself. I had this torque plate made for the final honing of my RB30 block. It was bored to 86.5mm. With the ARP head studs torqued down, we could see the block distortion at the stud locations.
evildky
06 Nissan 350Z GT
700 hp is a lot, and of course you boost levels to achiev that goal will be dictated by your choice of turbo(s) what turbo(s) are yu planning on running
raremotive
evildky wrote:700 hp is a lot, and of course you boost levels to achiev that goal will be dictated by your choice of turbo(s) what turbo(s) are yu planning on running
It's unknown due to a undecided turbo set. It will be determined sometime in the future when it's time for it.
Or in other words. I have a open list for twins. But right now I am working on the frame and setting the block up for it's build. Then I will be able truly sit down and decide which one will be up to the task.
Modified by Rare_f8 at 10:42 PM 11/5/2008
raremotive
Stealth-Z wrote:The torque plate idea floated around my mind for a long time. Finally I wanted to see for myself. I had this torque plate made for the final honing of my RB30 block. It was bored to 86.5mm. With the ARP head studs torqued down, we could see the block distortion at the stud locations.
Glad you were able to see some elastic deformation the cast iron really undertakes.
It's hard for me to make a torque plate all just for one time use.
minnesotazcar
Car: 1972 dautsun 240z
i have to agree for such a minor overbore i dont really see why a torque plate would be that nesessary espesially if your not going to have much use for it after that
Stealth-Z
Car: 1991 300ZX
Hopefully it will get more than one use. The person who will be doing the tuning on my motor wants to get in to building RB25's & RB26's. He has built quite a few high horse power Z32 Twin Turbo V6's.
74260zt
Car: rb26powered early 74 260z car
I had one made for myself also. The only thing I'd really really be carefull of, is over bore. I wouldn't go over 1mm....
raremotive
yeah I know. I really don't want to get any larger than 86.5
raremotive
I didn't notice it before, but that's a rb30 block.
How much did you pay for the torque plate?
Stealth-Z
Car: 1991 300ZX
$500
raremotive
Hmm, is there some way I can get a copy of a blueprint for that torque plate?
Stealth-Z
Car: 1991 300ZX
He used my block and head to make it. I will ask him after the holiday if he has a blue print for it.
raremotive
Cool thanks.
raremotive
Bump. Ever ask him?
Stealth-Z
Car: 1991 300ZX
Sorry, forgot about this. Will ask tomorrow.
evildky
06 Nissan 350Z GT
you can use a HG for a template, the RB and L6 actually can interchange torque plates
raremotive
Yes, good idea. I was just thinking blue prints and a billet.. and bounce around some machine shops or ask a friend to hook me up with his machinist friend.
Here's another example, of why I rather have a clear conscience: Done on a VG30DE Block
Rudi wrote:The block wasn't actually bored but honed oversized, reducing costs. He used the deck plate I supplied, with interesting result. He honed the bore to 87.50mm as the correct clearance for the 87.43mm JE pistons was 0.07mm. After honing he noticed the bore stretched 0.02mm (to 87.52mm) which in turn means that the head bolts literally pull the bore together reducing bore size by 0.02mm. If the bore was honed without the deck plate, the clearence would have been way less increasing the chance of a wrecked piston (ring).
Stealth-Z
Car: 1991 300ZX
Sorry, no blue prints. He used the block, head and gasket for measurements then made it.
raremotive
Hmm, ok. Thank you.
Return to “Datsun Z Forum”
