After 257k miles, my pickup, bought new in 1991, needed its first clutch replacement. I had to purchase an air compressor and impact wrench to break loose the bellhousing bolts. I have a table that shows correct torque specifications for each bellhousing bolt.
When reinstalling the transmission bellhousing:
Is it true that maintaining proper torque on each bellhousing bolt is problematical because you are forced to use a universal joint to install them?
Would using blue loctite on the bellhousing bolts make sense, as its use might make installing and removing the bolts require less torque, and you would have better assurance that the bolts are secure?
Are there mechanics out there who routinely use blue loctite?
And if so, how would they adjust the torque specifications for threaded fasteners, (which as near as I can tell are always spelled out for dry, clean, and unlubricated threads)?
