Torque Lbs on the Tension Rod and Upper Control Arm
bigdog76
Car: 1996 Infinity Q45
How much lbs of force with the torque wrench do I tighten on the tension rod and the upper control arm and is this done with the car is on the ground off the jack?
unknown007
Car: White 1993 Q45 (G50)
I accidently deleted my post.
It said,"Next time search up the FSM on the search and save it.Here's the download link:
http://www.nicoclub.com/FSM/Q45/1996_Q45/1996_Q45/
Tension rod72-87 ft-lbs
and upper control arm?you mean upper link?if so it's65-80 ft-lbs
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
TORQUE the tension rod when under load or yours will fail like mine in 20k. Do not torque with wheel off of ground.
unknown007
What you can do its lightly jack the rotor and to it .At least that's how I did so it gave it a load.The rack was being used at the time.I know a lot will do the palm face but I'm gonna redo it.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
unknown007 wrote:What you can do its lightly jack the rotor and to it .At least that's how I did so it gave it a load.The rack was being used at the time.I know a lot will do the palm face but I'm gonna redo it.
If you're not lowered like unknown, and thus the tension rod bushings may be inaccesible from the ground, it's best to torque when the car is on the ground, or on ramps for correct alignment of the bushing. Jacking the rotor works, but isn't 100% accurate.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ramps move weight off the front also.
Another instance where a lift is a blessing.
