vin27 »
https://forums.nicoclub.com/vin27-u178376.html
Mon Feb 07, 2011 11:17 pm
When I've checked the Transmission, it was up to operating temp, motor was warm, and I'd driven it at least 10 miles or so.
I'm just guessing it has something to do with a Throttle sensor, I'm having idling problems too! I thought that part of it has to do it with some flooding issue, and or the Fuel Injectors sticking while trying to start it. This has been happening for YEARS, I just floor the throttle and crank till it picks up, then ease off the throttle. If that doesn't start it, I've got a switch now to shut off the Fuel Pump, so I crank it with Open Throttle, once it runs smooth, turn on the fuel pump, starts every time! But the idle speed is off, about 1000 to 1300 at times.
When it does lock up, which it seems to be ok with at low speeds, under 50, it locks fine. On the hiway, it locks up every now and then, and when it does lock up, it's perfect! Through out the years, I've noticed the shifts 2-3 and 3-4 being a little slower then before. Sometimes it feels like it's curring power for a few seconds while the shift completes.
Anyway, what's the best way to check out the Throttle Sensors?
All the best,
Vin
