SUB ZERO CAR FANATIC »
https://forums.nicoclub.com/sub-zero-car-fanatic-u53284.html
Sun Nov 11, 2007 3:41 pm
I was in the process of installing my engine and Transmission back into the car after having done a good bit of work to engine and transmission has been completely rebuilt. Anyway im putting the engine back in with transmission bolted onto motor,as well as exhaust manifolds. I have it in place ready for motor mount nuts to be put on but im kinda worried about something. I used a engine leveler when putting unit in so that i would be able to tilt the rear of transmission down enough to get it to go in,well in the process of doing this when the transmission was tilted down some fluid leaked out of sides of transmission where lines bolt in. Im not concerned with the fluid that leaked out it wasnt much(1/4 quart at very most probably) im worried about how much fluid is left in the TORQUE-CONVERTER!! There should be over 2 quarts in the converter, if it all leaked out to inside the transmission then i dont know how much is left in the converter if any! will it hurt to drive it not knowing how much fluid is left in converter?? please help Q45 TECH or any one else that can. much thanks guys, SUBZERO
