Torque Arm Replaced on top of the engine
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Milkmaster
Car: 2007 Versa S Hatchback
The Versa I bought a month or two ago shifted easy but seemed to buck back and forth much more than I would consider normal. I found the torque arm bushing on the top of the engine worn out and split. The part cost was $72 from Nissan and was a 10 minute repair. The car drives much smoother now. I would imagine that stick shifts are much harder on this bushing than those with an automatic. The constant back and forth motion of the engine during shifts can wear it out, or at least that is what I have discovered. I suggest you take a look at your own Versa for the same evidence of failure. Mine has 86K miles on it. Good Luck and report back here what you find!
I would attach some pictures, but I cannot determine the way to do that on this forum.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
Milkmaster wrote: I would attach some pictures, but I cannot determine the way to do that on this forum.
host them on a place like Photobucket and then paste the link with the " Img " button.
Return to “Versa Technical Discussions”
