Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Sat Sep 14, 2002 7:21 pm
turbulence in the pipe could be good, if your using it in the form of a VG or Vortex Generator. They use them all the time in jet engine inlets, (esp. in like a 727 where there is an S pipe leading into the compressor inlet).
If you can get the air swirling in a tight spiral it will flow more and faster than if it's just going in on it's own (especially around corners IF you can make the vorted bend). They've been using VG's on the wings of planes for years to lower stall speed's, increase climb performance, and the weight capacity of the AC.
but back to the original topic, that thing sucks.... did you know how they got the 'dyno proven HP'? They did one pull in 4th and after adding it they did it in 3rd....
anyhow, save your money for some new headlight fluid or a muffler bearing......
