Topmount turbolines on sr redtop Question???
Slideways^Jordan
Car: 1989 240sx Coupe-1991 240sx Hatch back
I just want to clearify this one i think its the water inlet line of the water cooling line does it run to the back of the engine along with the heater hose is this correct. i think so.
And also i need to get a oil return line made to run from the turbo down to the botom of the engine to screw in to the the oil line adapter
Im loading pics now
:pics now up:
why is their orange liquid gasket comeing out my valve cover gasket WHY it cant be can it
Modified by Slideways^Jordan at 7:36 AM 11/12/2007
Modified by Slideways^Jordan at 7:41 AM 11/12/2007
Modified by Slideways^Jordan at 7:42 AM 11/12/2007
Modified by Slideways^Jordan at 7:44 AM 11/12/2007
greenmonster80
Car: KGC10
Looks like you got the water inlet correct. Just remember there is an outlet line as well. same for the oil. There is an inlet line. Both connect from the turbo to the block. the orange silicone is correct. FSM states to apply a continuos bead around the 4 lobe areas of the valve cover gasket.
Slideways^Jordan
greenmonster80 wrote:Looks like you got the water inlet correct. Just remember there is an outlet line as well. same for the oil. There is an inlet line. Both connect from the turbo to the block. the orange silicone is correct. FSM states to apply a continuos bead around the 4 lobe areas of the valve cover gasket.
ok thanks yeah i have the return and inlet lines but not the return for the oil cuase that line didnt come come with the topmount turbo lines
oh and about the orange silicone i was trying to be funny i know its right well like its obvious somthing was upgrade in the head cause the factory silicoe is gray if you know (I did a head build with BC 272 cams new rocker arms, BC springs andBC retainer and Tomei solid lifters and P2M RAS.
Thanks for the info greenmonster80 i appreciaye it.
