Rogue Rattling Noise - Heat Shield?
gem0183
Car: 2011 Nissan Rogue
Hello!
I am hoping someone can give me some guidance. This morning, as I was driving to work, I started hearing a rattling noise coming from the front passenger side of the car when I was stopped at a red light. The noise doesn't start immediately when I come to a stop, but starts after about 30 seconds. It only makes the noise when the car is in drive. If I put the car into reverse or park, the noise stops.
Any suggestions on what could be causing the noise? And if it needs to be checked/repaired, an estimated cost?
Thanks!
Reason: Revised title
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
gem0183 wrote:Hello!
Thanks!
My 2013 had the same issue but was fixed under warranty per this TSB:
Subject: SB 2008-2014 Rogue Exhaust Center Tube Heat Shield Rattle
Summary of NTB14018:
IF YOU CONFIRM A rattle coming from the exhaust center tube heat shield, and a heat shield spot weld is detached, ACTION Install a band clamp around the heat shield and over the detached spot weld. See this bulletin for further detail.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
its probably, Heat Shield Rattle, which is common on every car
deb1262
Car: 2014 Nissan Rogue
I had the same rattle. I took it to the dealer and they said it was a heat shield. It made the same noise as soon as I pulled out of the lot. I took it home and hubby reached underneath and bent it up a little. Never had a problem again.
gem0183
The dealer told me it was the alternator and it needed to be replaced, but the car starts fine and runs fine. I told them that I didn't want it fixed today and I would get a second opinion. Does this sound possible? The car is only 4 years old.
phmichel
Guys - there's a TSB for this. Read the 2nd post...
darylzero
I will be looking into this when I have time this weekend. My heat shield has been rattling for a while now, but it's gotten very bad lately.
I did find a copy of that TSB, http://i.imgur.com/ty0Z1N7.png
darylzero
My noise was due to the exact same spot on this TSB. The one weld came loose and was rattling. I thought it was going to be more than one weld that came loose from all the noise, but I put the band clamp on it and it's quiet once again :dblthumb:
N.Y.C.H
I am experiencing a rattle about 60% of the time when i hit a bump coming from somewhere in the front. Along with this the passenger window when in any other position other tan completely closed or completely opens kind of like rattles as well. Doesn't seem like it is totally secure. Are there any quick fixes for either of these or will the dealer be able to fix them for me?
2015 Rogue
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
5.56 wrote:its probably, Heat Shield Rattle, which is common on every car
We have an incredible SEARCH feature on this forum. Merged with existing thread.
--------> READ BEFORE CREATING NEW THREAD! <--------
Reason: Topics merged
N.Y.C.H
The noise isn't wen coming to a stop, its just when i hit a bump every once in a while, coming from either the dashboard or somewhere infront.
ImStricken06
2016 Kia Sorento
there is no way we can tell you, without an audio clip at the very least. there are 100,000+ parts on a car.
it could be either of 4 struts, 4 strut bushings, 4 hub bearings, 2 sway bars, hood, etc.
head to the dealer mate.
08roguesl
Car: 2008 Nissan Rogue SL AWD
I've noticed that when I come to a stop or decelerate I hear like a rattle noise coming from the front of the engine. I will be posting a video tonight.
Rogue One
2022 Honda Pilot SE
I've revised your title. Please take a moment to read this:
2. USE THE CORRECT TITLE: That means, make sure your title has the topic at hand. Don't title something: "I have a question" or "Small concern" or "Rogue issues". Instead title it: "Tire tpms question" or "Rear bumper paint issue".
rick2130
check your exhaust heat shield
darylzero
rick2130 wrote:check your exhaust heat shield
+1
yep very common on the 08 and 09 models. Nissan has a TSB about it.
08roguesl
I have a video trying to upload it...
08roguesl
08roguesl
Can anyone help me with this issue please.
Rogue One
2022 Honda Pilot SE
08roguesl wrote:Can anyone help me with this issue please.
They did. See...
Did you check it? If so, was it loose? If you didn't check, please explain why you didn't.
BTW, have you taken the vehicle to a mechanic?
ImStricken06
2016 Kia Sorento
there is no way for us to tell. its something to do with the vehicle speed. maybe rotors, shafts, transfercase, etc. head to a mechanic.
08roguesl
Ok will do I know I had the heat shields removed a few months ago... I know my brakes are done...
08roguesl
Imstricken did you checkout the video?
ImStricken06
2016 Kia Sorento
yes i did. there is no one who could identify that noise.
08roguesl
Ok thank u for looking... Sorry for being annoying... I'll keep you guyz posted.
Laserbug
Car: 09 rogue
I just fixed some rattles from my ROGUE engine compartment, and I must say, I tried to pat myself on the back afterwords.
Anyway, two things I found pretty quickly were air filter plastic supply tube being slightly loose and banging against the wheel well underneath. For this I used a 1/4 inch approx chair felt floor pad in the little space top of wheel well against filter tube.
OK. Other problem was the radiator reservoir. Same problem, same fix. I took my Rogue out on rough road put it through a pothole test and hey, rattles gone! P.S. These rattles really sound like it's a suspension bushing problem. So check the simple things first. From inside a car, a small rattle can sound massive due to drum effect of metal.
HOPE THIS HELPS SOME. DEALERS will NOT check these little things. You know why? $$$$$.
Reason: Typo
08roguesl
Ok thank u for the info...@ laserbug... Can u take a pic for me so I can see exactly what I'm looking for
OMAR6575
Car: 2017 NISSAN PATHFINDER S 4WD
:confused: i have a 2014 nissan rogue select, there is a ratle under the front end, i have search the entire front end for any signs of play or loosen fasteners, dealer can replicate but cant pin point, it happens under an specific frequency of bumps
its very strange, has anyone experience this ??
Reason: Merged with existing thread
Rogue One
2022 Honda Pilot SE
OMAR6575 wrote::confused: i have a 2014 nissan rogue select, there is a ratle under the front end, i have search the entire front end for any signs of play or loosen fasteners, dealer can replicate but cant pin point, it happens under an specific frequency of bumps
A1850
Hi all. New to the forum and I did a search but didnt find anything. I bought a used 2013 Rogue. Still under warranty (yay) I noticed that at high speeds, 75/80mph (not that i drive that fast...) i hear a knocking noise under the hood. Intermittent. Like aluminum hitting itself. Ity happens Only at high speeds. I Havent been able to figure out what it is. Thinking it may be a loose heat shield or something. Any suggestions? thanks!
Return to “Rogue Forum”
