xrider252
Car: 98 kouki
ok so i have a 93 vert and i want to swap my CA enigne in the car, as u know the vert are auto so would this work just swap bellhousing, flex plate, is it that easy or what. i dont have the time or money for a 5spd swap right now, putting it off to the winter lmk what u guys think
mbmbmb23
KA bellhousing wont swap over to CA, auto or manual. You'd also have to source an A/T CA ecu and probably a few items for the wire harness (im assuming there is something). Assuming your CA is 5 speed right now, you are better off doing a 5 speed conversion to your 240sx. There are write ups on the boards and the parts aren't that expensive depending on what junk yard you go to.
-m
xrider252
Car: 98 kouki
yes my ca is 5 speed, so could i use that bellhousing or do i need a automatic one.
xrider252
Car: 98 kouki
xrider252 wrote:yes my ca is 5 speed, so could i use that bellhousing or do i need a automatic one.
well thxs for the info i think im goin to keep the CA in the car it in already and just buy another ka for the vert thxs again
