MadSideways »
https://forums.nicoclub.com/madsideways-u3356.html
Mon Apr 28, 2003 7:28 am
I just got done installing the LSD out of a 95 j30, into my non-abs s14 240sx.
There were no fitment problems at all. The thing went right in. I didn't even remove the swaybar or exhaust. The stock driveshaft fit perfectly, (even though its longer), like it was meant to be that way. And the j30 diff comes with the 3x2 bolt-pattern output shafts, (just like the 240sx), so there was no need to buy new ones.
The only problem I had was, vibration at first, but then I realized that the driveshaft and LSD weren't lined up. The driveshaft has a yellow line on the bottom, and the LSD has a white dot on the bottom, and it's imperitive that they be lined up, or the whole thing will be out of balance. Once I corrected it, the vibration went away.
The results are well worth it, accelleration is a tad-bit less due to 3.917 final drive, (as apposed to the 4.083 stock). But it actually feels more like a sports coupe now instead of a high-winding truck, as it did with the old diff. Drifting is much smoother and predictable now. And I've noticed a 25% increase in entry/exit speed for turns.
The speedo is off, (4.07% fast), but purchasing a new speedometer pinion from courtesy nissan should fix that. Although, I'm not sure exactly which one to purchase.
