TopCowl Seal adhesive?
Mad_skids
Car: 1991 300ZX
I'm sure someone has answered this before but my searches have come up nothing on it;
Recently bought a z32 US spec Cowl kit to replace my old dry-rot one. it looks amazing, got it cleaned, primered, and painted black, but it didn't come with any adhesive?
what should be used and where do i get it?
it can't go on dry right?
NolimitZ32
These are mounted with fasteners not double stick tape, if it wasnt drilled for the screws you'll have to lay it out.
Mad_skids
Car: 1991 300ZX
Yeah, it is drilled for the clips but the confusion is the rubber seal that they sent with it. The old one came off without having to peel It because of dry-rot I think, so I don't know if I should use m3 Window sealer or I'm not supposed to use anything
NolimitZ32
The rubber seal that goes between the cowl and the windshield is supposed to slot into the shaped receiver on the cowl. There should be no adhesive needed.
