Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Apr 10, 2008 9:21 am
I can't remember the wire colors off hand, but you make a jump at the dash plug. The dash switch gets its power from the inhibitor plug, so you just wire it up to something that has uninterrupted power. Preferably something on an ignition switch so the top can only be put up/down when the car is on.
Then all you do is jump the drive wire at the inhibitor plug like we've been doing for the park circuit. That way the ATCU thinks you're in drive and the cruise will work. The problem right now is that if the ATCU thinks it's in park, the cruise defaults to off. Even if you have the drive circuit powered at the same time.
Years ago, someone used a rocker switch to switch the ATCU between park and drive, but it required popping the hood to do because he wired it at the inhibitor plug.
We're going to be finishing up a vert swap for one of my good friends, so I'll be sure to snap shots of my dash wiring.
