Thats exactly what i said, You turn the driveshaft one time for the wheels to rotate over 4 times. And your right, the R32 GTR uses a 4.111 R&P Front and Rear. Either way, its only a mph or so difference that 4.083.jdm_master_X wrote:actually you have to spin the larger of two gears to determine gear ratio. in this case you spin either output shaft until the pinion shaft has rotated once.
and there actually is a 4:11 gear ratio.
