Top speed
bp2ooo
I searched and didn't see anything, so i am asking. If i were to go on a really big strait away what is the top speed of a sr20det? And since i know it will depends on mods, just assume its stock. I know greddy has a speed cut eliminator for like 80 bucks. How much faster would the car be able to go?
BuudWeizErr
118mph.
themadscientist
If I can go 130mph in a CA18DE (speed cut defeated) I would think an SR20DET would go faster than that.
SpeedRacer1
Car: 1990 240SX, G35
Well mine cuts out at about 125-130, and you dont need a huge stretch to get it that fast;). The only bad thing is that the governer kicks in at 5000(ish)RPM's in 5th gear for me. This means that if you buy a speed defencer you only have about 2500RPM's left after 130 before the engine is redlining.
bp2ooo
SpeedRacer1 wrote:Well mine cuts out at about 125-130, and you dont need a huge stretch to get it that fast;). The only bad thing is that the governer kicks in at 5000(ish)RPM's in 5th gear for me. This means that if you buy a speed defencer you only have about 2500RPM's left after 130 before the engine is redlining.
2500 rpm left doing 130 would probably get me to like 140-150 ish. Im thinking that will be cool as hell. Thanks
themadscientist
gears baby, gears
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
themadscientist wrote:gears baby, gears
thats what i wrote but my post didnt show up or something. unless you have too little hp you max speed is determined by gearing and redline which i belive come at about 140-150 (i heard 148 somewhere) without govern.
pampadori
Car: 91 Nissan 240SX coupe
that sounds a little slow, i thought more like 155mph. you can get a 300zx tt diff and go faster. they are 3.8????i can't remember. another thought, my old ka 5 speed was geared taller. i was at like 3000 rpm at 70mph. the sr gears are shorter and i'm at about 3500 rpm at 70mph. do both mods and get about 185? higher?shaun
Onizuka
you just need new gears from JUN or some other company that offers that kind of thing.
Edit: im kind of interested in the same thing only i just want a taller fifth gear for highway driving. does anyone know if I can swap 5th gear from my ka transmission to sr?
Cyberkreig
Car: 1993 Nissan 240SX SR
arent he KA and SR internals the same?
Daunttless
yes.
pampadori
no. they aren't. 5th gear is taller on a ka. why does everyone always say that? at 60mph in ka i was just under 3000rpm. in both of my sr's, i'm at 3500rpm. so, NO.shaun
Cyberkreig
Dauntt - are the Sohc and dohc trannies the same too?
shaun, could that be because the SR makes less power/torque under 3000rpm than the KA?
TheProfessional
Car: movies, music, cars
cyberkreig... agreed. the sr20 has completely different characteristics than the KA, therefore, the trannies could be identical (which they practically are) and can have different top speed as well as different RPMS at MPH. bp2000, do you plan on going over 130 or something? if you get caught, remember the best invention of the 20th century... "soap on a rope."
Onizuka
pampadori wrote:no. they aren't. 5th gear is taller on a ka. why does everyone always say that? at 60mph in ka i was just under 3000rpm. in both of my sr's, i'm at 3500rpm. so, NO.shaun
he was refering to the fact that gears can be swaped between the two.
BTW, that is strange because im at 70 at about 3050 on my ka
pampadori
woo! i wish my sr was at 3050 at 70mph. i'm thinking about getting a speed sensor and lsd from a tt 300zx. they have a good rear end ratio for higher speed driving. shaun
SpeedRacer1
Well according to my Speedo and Tach my SR runs like this:65MPH = 3000RPM70MPH = 3300RPM75MPH = 3500RPM80MPH = 3750RPM85MPH = 4000RPM
Onizuka
pampadori wrote:woo! i wish my sr was at 3050 at 70mph. i'm thinking about getting a speed sensor and lsd from a tt 300zx. they have a good rear end ratio for higher speed driving. shaun
This might mess up things for daily driving in low gears.. just get a KA fifth gear and swap it in.
EDIT: i was refering to the fact that a 300zx TT lsd will mess up your final drive.
Dori Dori
Car: Cars of course
Power and torque have nothing to do with it. If the gear ratios were exactly the same, the diff ratio was exactly the same, and the wheels/tires were exactly the same, both engines would be running the same speed at the same rpm in the same gear. So if a KA transmission has the same ratios as a SR transmission (which I have no clue about) then they will both be at 'x' speed at 'y' rpm in 'z' gear . They can have different top speeds though, only because they have different power/torque levels.
Dori Dori
Car: Cars of course
S13 Silvia K's 5MT gear ratios
1st.........3.3212nd........1.9023rd.........1.3084th.........1.0005th.........0.759
Reverse...3.382
Final Drive ratio = 4.083
Fixed info...
Cyberkreig
Dori - Thanks for the answer. I didnt know, thats why I offered the idea as a question. Not gonna lie, dont know anything about gears.
pampadori
SpeedRacer1 wrote:Well according to my Speedo and Tach my SR runs like this:65MPH = 3000RPM70MPH = 3300RPM75MPH = 3500RPM80MPH = 3750RPM85MPH = 4000RPM
that isn't what mine is at. i have a early redtop. i am using a 300zx na diff, and the ka speed sensor. any idea why mine is different? btw, the speedsensor takes its reading from the tail shaft, so tire sizes won't effect what my speed says. only "actual" speed. so why am i off? fwiw, my friends sentra is the same as i am at 60mph.shaun
Onizuka
Dori Dori wrote:Power and torque have nothing to do with it. If the gear ratios were exactly the same, the diff ratio was exactly the same, and the wheels/tires were exactly the same, both engines would be running the same speed at the same rpm in the same gear. So if a KA transmission has the same ratios as a SR transmission (which I have no clue about) then they will both be at 'x' speed at 'y' rpm in 'z' gear . They can have different top speeds though, only because they have different power/torque levels.
What you say is all true but top speed is determind by gears and only gears. For example, assume you have a KA and SR (with identicle transmission's) driving on the same surface that is perfectly level and wind is perfectly still. both will reach the same maximum speed (assuming they have the same redline) but the only difforence is that the more powerful car will get there quicker, assuming the two are aerodynamicly identicle.
James
Car: Nissan S14 tuned for the Shuto Expressway
Anybody actually try and throw the math at this cause I did and it was a pretty high top speed math wise with the gears and 225/50R-16 tires. I was getting to about 170, granted there is alot more then that going on when you actuall get going that high to be able to say that she'll top out at 170-James
Onizuka
you would have some serious control and safety issues to look at before you even get close to that speed. I got about 149.18 mph as the KA24de top speed at 6500 rpm. the sr has shorter gears than the ka, but higher revs so they are probably very close in top speed.
Th*GgEd_OuTtTt
yes wat would a 300zx tt lsd do in terms of speed? what would your top speed be if u had an s13 sr transmission with 300zx tt diff?
Onizuka
it would be higher but you wouldn't make enough power to push it all the way and you would have problems accelerating. I dont know what the gearing of a tt 300zx lsd is...
Munki4ce
Car: Hick things and cars
i have hit 230-240kph on mine:( i dont know what that comes out too. My exhaust temp was getting too high so i didnt go any faster but i know it had a little more left in 'er :)
Dori Dori
Car: Cars of course
J-Spec Tuner, Top speed is not, I repeat, IS NOT only determined by gearing. You are wrong, wrong, WRONG; and I hope nobody buys into that load of B S. There are 3 main factors that determine a cars top speed. Gearing, drag, and POWER (hp that is). Why do you think that top speed cars have insane power? To overcome drag. In your scenario of every other factor remaining constant, the more powerful car will have the higher top speed. Period.
Go here to find out why:http://www.perry-lake.k12.oh.u....html
If you read it and understand it, you'll know that you will need roughly 23% more power for a 10mph increase in top speed. Given the power of a stock KA (155hp) and the power of a stock red top SR (205); the SR has a power increase of roughly 32%. That means it could go around 15mph faster...all other variables remaining constant (assuming that gearing and redline allow and that the car's top speeds are drag limited).
Also, unless you are measuring with GPS, your top speed read outs are flawed b/c your speedo becomes very unreliable after 90-100mph. Chances are you are not really going that fast.
ADAMHU
if gearing is the same....and both cars have enough power to punch thru the air...then the car with the highest RPM will go the fastest...
the fastest i had my KA24ET going was 255kph...and it was revved out...so it was rpm limited.....
