PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Wed Jan 02, 2013 10:54 pm
You could try 2 things. First, you could loosen the exhaust, and jam a shim in there between the tip and the bumper (you might want to cover it in felt or something to prevent scratching) and then re-tighten it up.
The other option is to stick something down in the exhaust (like a long pipe) and bend it down a little bit.
