4banger wrote:I cut the wire and added a toggle switch going to the ecu and I still have the limiter problem it dosen't stall the same as it did before, its more of a studdering now when I hit 115mph. It would only goto 111mph before I cut the wire and then the car would just stall like it was running out of gas. The wire is the 8th one down on the left of the ecu harness yellow wire w/ green stripe. It took me about five minutes to even get the balls to cut it. I just ran the wires over by the driver in the dash and then stuck a 2 lead toggle switch, that i can switch of and on. When you flip the switch off the check engine light comes on doesn't seem to do anything wrong but don't quote me on that. Tonight was the first time I tested it. I have heard that if you unplug the 5th gear sensor that it screws it up and the car does nothing when you shift into 5th. I don't know what they meant by nothing, but I'll soon find out and let you guys on the forum know.
trpower7 wrote:Kind of wondering, if you unplug that sensor would you give a place for transmission oil to leak out of? I suggest leaving the sensor in and cutting the wire to it, or if you can unplug the harness at the sensor even better.
