SqueekyQ »
https://forums.nicoclub.com/squeekyq-u30546.html
Mon Jul 11, 2005 4:46 pm
My 94 Q is acting up lately.
One day after I made a left turn I couldn't accelerate. It stays in one gear and lurches when I floor the gas paddle. It will shift if I press the gas slowly and gently. I though there is something wrong with the transmission.
After a while the problem went away for a couple of days. It shifts but the rpm will drop and die when I brake hard or put in neutral or park.
The next day, it won't die but it won't shift again. So I did something I should have done, I put it in park and floor the gas. The rpm goes up to 3000 and stops there, if I try again, it will go to around 4000 and stop. At the same time, the muffler is pass gas like all the crappy cars in the movies.
From my simple diagnose, it doesn't look like a transmission problem. It might be an air / gas related problem.
Car info
94 Q, 167000 miles. Humming gas pump.
4 years ago, replaced air meter ($700 at Infiniti dealer) because of rpm drops and engine dies.
3.5 years ago, same problem(rpm drops and engine dies) occurred, spray clean the EFI throttle body with one bottle of cleaner ($2)
Sometimes hard to start after sitting in the garage for days.
1.5 years ago, changed transmission fluid, drop pan.
Recently moved to Florida. Hot and humid and full of small animals
3 months ago: Clean EFI throttle body, replaced Air meter connector due to same problem I am having now . Also replaced belt tensioner.
2 weeks ago: Fuel injector cleaner, water remover in two seperate tank of gas.
