top or bottom?
FrankieBonez
Car: 1990 240sx
I've heard alot of things about having to install an rb from the bottom of the car. I have an rb25 that is going in next weekend and im curious, can it go in from the top? is it much more difficult? If its easier to go from the bottom, when did everyone use to hold there cars up? I tried to seard but the engine is down for some reason. Any info would be appreciated
420_240
either way, top or bottom is possible... depending on your preference and resources will depend on which route you take... I installed my motor from the bottom.. had the car up on jackstands.
FrankieBonez
Car: 1990 240sx
WHat sources would i need to install it from the top, the people that are helping me and the limited space i have to work with would just make it easier that way, i have an engine hoist but what else would be needed. Am i gonna need to prop the front of the car up anyway and bring it in on an angle?
JonPowell
Car: Cars, Music, My family
Gonna need to get the body PRETTY HIGH in the air to get the proper angle on the engine/trans combo...high enough that you might as well go from the bottom.
Going from the top is easy if you seperate the engine/trans and reassemble once the motor is in place.
For holding the car up there is a new invention called a "jack stand" not too many people have heard of them, but you can get them in varying heights depending on your needs.
420_240
420_240 wrote:I installed my motor from the bottom.. had the car up on jackstands.
JonPowell wrote:For holding the car up there is a new invention called a "jack stand" not too many people have heard of them, but you can get them in varying heights depending on your needs.
... thank you... thank you
Carl H
i prefer to install rb20's from the top, rb25's ive never really done so i cant say.
theXfiend
Car: 1992 240sx coupe SE w/ rb25det
rb25 from the bottom took about 5 minutes.
SeVa-S13
Car: '05 GTO 6spd
Do not do an RB20 seperate from the transmission (atleast without the expensive mounts) is all I have to say. I'm not the only person to have to change a clutch and disconnecting and then reattaching the transmission while the engine is still in is a b****.I did it from the top, took maybe half hour with 2 other guys who had enevr done an engine swap before. That's from engine in the air to everything bolted in. Oh, and make as sure as possible that the engine is level side-to-side -- really helps.
420_240
in all honesty... it's basically just a bunch of adjusting... then readjusting... and a hella lot of push and pull
